文件系统加载错误
幼儿园
发表于 2016-7-22 17:33:26 | 显示全部楼层 | 阅读模式
有块板子9X25一开始运行是好的,几天后出现加载文件系统:
UBIFS: background thread "ubifs_bgt0_0" started, PID 657
UBIFS: recovery needed
UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x9f4521f3, read 0x773d4c93
UBIFS error (pid 1): ubifs_check_node: bad node at LEB 388:108784
        magic          0x6101831
        crc            0x773d4c93
        node_type      0 (inode node)
        group_type     2 (last of node group)
        sqnum          44579
        len            160
        key            (346, inode)
        creat_sqnum    1010
        size           2048
        nlink          6
        atime          1461809868.0
        mtime          1475674248.0
        ctime          1467285640.0
        uid            1000
        gid            1000
        mode           16895
        flags          0x1
        xattr_cnt      0
        xattr_size     0
        xattr_names    0
        compr_type     0x1
        data len       0
CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.0 #20
[<c000e3f0>] (unwind_backtrace+0x0/0xe0) from [<c000bfc4>] (show_stack+0x10/0x14)
[<c000bfc4>] (show_stack+0x10/0x14) from [<c013d11c>] (ubifs_check_node+0x27c/0x2b8)
[<c013d11c>] (ubifs_check_node+0x27c/0x2b8) from [<c0143cf0>] (ubifs_scan_a_node+0xb8/0x1c8)
[<c0143cf0>] (ubifs_scan_a_node+0xb8/0x1c8) from [<c01441a4>] (ubifs_scan+0x54/0x2e4)
[<c01441a4>] (ubifs_scan+0x54/0x2e4) from [<c0144f3c>] (ubifs_replay_journal+0x844/0x134c)
[<c0144f3c>] (ubifs_replay_journal+0x844/0x134c) from [<c013a514>] (ubifs_mount+0xb38/0x14c0)
[<c013a514>] (ubifs_mount+0xb38/0x14c0) from [<c0082aa0>] (mount_fs+0x10/0xc0)
[<c0082aa0>] (mount_fs+0x10/0xc0) from [<c0095e18>] (vfs_kern_mount+0x48/0xc4)
[<c0095e18>] (vfs_kern_mount+0x48/0xc4) from [<c0097ca4>] (do_mount+0x6ac/0x7a0)
[<c0097ca4>] (do_mount+0x6ac/0x7a0) from [<c0097e1c>] (SyS_mount+0x84/0xb8)
[<c0097e1c>] (SyS_mount+0x84/0xb8) from [<c0632bfc>] (mount_block_root+0x12c/0x250)
[<c0632bfc>] (mount_block_root+0x12c/0x250) from [<c0632fa4>] (prepare_namespace+0x88/0x1b8)
[<c0632fa4>] (prepare_namespace+0x88/0x1b8) from [<c06328fc>] (kernel_init_freeable+0x170/0x1b4)
[<c06328fc>] (kernel_init_freeable+0x170/0x1b4) from [<c04884a0>] (kernel_init+0x8/0xe4)
[<c04884a0>] (kernel_init+0x8/0xe4) from [<c00093b0>] (ret_from_fork+0x14/0x24)
UBIFS error (pid 1): ubifs_scan: bad node
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 388:108784
UBIFS error (pid 1): ubifs_scanned_corruption: first 8192 bytes from LEB 388:108784
UBIFS error (pid 1): ubifs_scan: LEB 388 scanning failed
UBIFS: background thread "ubifs_bgt0_0" stops
VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0): error -117
Please append a correct "root=" boot option; here are the available partitions:
