N32926开发板启动出现错误:Freeing init memory: ***K
幼儿园
发表于 2016-12-23 11:32:19 | 显示全部楼层 | 阅读模式
开发环境是N32926开发板自带的VM开发环境,
交叉编译工具为:arm-linux-gcc4.5.1
编译开发板已配备好的配置busybox1.15.2
[align=justify]
make ARCH=arm
[align=justify]
CROSS_COMPILE=/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-gcc
[align=justify]
make install
[align=justify]
编译开发板已配备好的kernel,
./build nand
复制生产的conprog.bin到开发板上,就出现了Freeing init memory: 1028K错误:
Initial RTC
SD Port 0 Booting Fail - No/Unknown Device
NAND CS0 Booting 2K-Page(5) BCH T4 PPB 64
     Write - 0xB0000004 = 0x00032FFF
     Write - 0xB0000208 = 0x00008350
     DRAM CMD0
     DRAM CMD1
Success
Execute Address 0x00900000
FA92 Nand Boot Loader entry (20131225).
1111113.Bp3:
System clock = 240,000,000Hz
DRAM clock = 360,000,000Hz
Enable RTC power off feature to 6 seconds.
Get image information from block 0x0 ..
Load file length 0x44FFC, execute address 0x800000
Nand Boot Loader exit. Jump to execute address 0x800000 ...
NVT Loader Start
PWRON =  0x60085
NVT Loader: g_ibr_boot_sd_port = 0
N3292 UDC Library (20140313)
[GNAND] GNAND Library Version: V1.02.4
Initial NAND NonOS Driver (20140708) for NAND port 0
NAND: Found SLC NAND, ID [01][DA][90][95][44], page size 2,048, BCH T8
uIBRAreaSize = 4 blocks
[GNAND] NAND flash chip detected, chip ID is 0x1-0xDA !
Total Disk Size 254,848 KB
KPI  Key Code = 0x0
kernel found
Jump to kernel
Jump to kernel aaaaaa
Linux version 2.6.35.4 (root@cust-VirtualBox) (gcc version 4.5.1 (ctng-1.8.1-FA) ) #255 PREEMP
T Fri Dec 23 10:53:30 CST 2016CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
CPU: VIVT data cache, VIVT instruction cache
Machine: W55FA92
Memory policy: ECC disabled, Data cache writeback
CPU type 0x00fad007 is W55FA92
w55fa92_external_clock = 12.0 MHz
w55fa92_upll_clock = 240000 KHz
w55fa92_apll_clock = 432000 KHz
w55fa92_mpll_clock = 360000 KHz
w55fa92_system_clock = 240000 KHz
w55fa92_cpu_clock = 240000 KHz
w55fa92_ahb_clock = 120000 KHz
w55fa92_apb_clock = 60000 KHz
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: root=/dev/ram0 console=ttyS1,115200n8 rdinit=/sbin/init mem=64M vt.global
_cursor_default=0PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 37976k/37976k available, 27560k reserved, 0K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xff600000 - 0xffe00000   (   8 MB)
    vmalloc : 0xc4800000 - 0xe0000000   ( 440 MB)
    lowmem  : 0xc0000000 - 0xc4000000   (  64 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .init : 0xc0008000 - 0xc0109000   (1028 kB)
      .text : 0xc0109000 - 0xc04d2000   (3876 kB)
      .data : 0xc04d2000 - 0xc04fc1a0   ( 169 kB)
Hierarchical RCU implementation.
RCU-based detection of stalled CPUs is disabled.
Verbose stalled-CPUs detection is disabled.
NR_IRQS:47
Console: colour dummy device 80x30
console [ttyS1] enabled
w55fa92_avc_alloc_mem at phy =0x521000, vir_addr = 0xc0521000
ENCODER_TOTAL_SIZE = 0x42f000, DECODER_TOTAL_SIZE = 0x77b000
Instant num = 1, total required memory is 0xbaa000, now kconfig size = 0xbaa000
Encode 1 instance total size =0x42f000
w55fa92_avc_alloc_mem, dec_bs_phy_buffer = 0x950000, dec_ref_phy_buffer = 0xaa2000, mb_info_ph
y_buffer = 0xd45000w55fa92_avc_alloc_mem, out_phy_buffer = 0x521000, enc_recon_buf = 0x673000, enc_refer_buf = 0x
7c5000w55fa92_avc_alloc_mem, dec_out_phy_buf = 0xd47000, _DECODER_BUF_START = 0x950000, DECODER_SUBT
OTAL_SIZE = 0x3f7000Calibrating delay loop... 119.19 BogoMIPS (lpj=595968)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
Advanced Linux Sound Architecture Driver Version 1.0.23.
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource w55fa92-timer1
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
register clock device
w55fa92_edma_init
ROMFS MTD (C) 2007 Red Hat, Inc.
msgmni has been set to 74
alg: No test for stdrng (krng)
io scheduler noop registered (default)
---w55fa92fb_init ----w55fa92 frame buffer init
###########w55fa92 frame buffer probe############
1*** fbi->fb->fix.smem_len = 0x7f800
init Hanstar panel !!!
check_var(var=c3c52020, info=c3c52000)
w55fa92fb_set_par !!! =================
var->width = 0x1e0 !!!
var->bits_per_pixel = 0x10 !!!
Console: switching to colour frame buffer device 60x34
w55fa92 LCD driver has been installed successfully
w55fa92 SysMgr driver has been initialized successfully!
fa92 vpe register char device Successful!
w55fa92 VPE driver has been initialized successfully!
W55FA92 uart driver has been initialized successfully!
w55fa92-uart0: ttyS0 at MMIO 0xb8008000 (irq = 14) is a W55FA92
w55fa92-uart1: ttyS1 at MMIO 0xb8008100 (irq = 30) is a W55FA92
brd: module loaded
loop: module loaded
w55fa92_avc_init
fa92 AVC Decoder Supported
FAVC Decoder IRQ mode(33)v1.0
fa92 AVC Encoder Supported
FAVC Encoder IRQ mode(34)v1.0
H264 Driver Version v1.0
The H264 Driver init OK and Max Resolution is 1280x720
### W55FA92 ether driver v0.1 has been initialized successfully!
>mcuzone: W55FA92_ETH_PORT1 INIT!
>mcuzone: GPDFUN0: GPD[3:0]!
>mcuzone: GPDFUN1: GPD[11:10]!
>mcuzone: GPGFUN0: GPG[5:2]!
>mcuzone: W55FA92_ETH_PORT1 DONE!
rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
usbcore: registered new interface driver rtl8150
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
USBH2.0 Clock source is UPLL, divider is 5
REG_OpModEn = 0x00010000
w55fa92-ehci w55fa92-ehci: Nuvoton w55fa92 EHCI Host Controller
w55fa92-ehci w55fa92-ehci: new USB bus registered, assigned bus number 1
w55fa92-ehci w55fa92-ehci: irq 21, io mem 0xb100b000
w55fa92-ehci w55fa92-ehci: USB 2.0 started, EHCI 0.95
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
USB device plug in
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd_w55fa92_drv_probe
usb_hcd_w55fa92_probe
w55fa92-ohci w55fa92-ohci: Nuvoton W55FA92 OHCI Host Controller
w55fa92-ohci w55fa92-ohci: new USB bus registered, assigned bus number 2
w55fa92-ohci w55fa92-ohci: irq 22, io mem 0xb1005000
ohci_w55fa92_start
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
USB device plug in
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
<--w55fa92_udc_probe-->
mice: PS/2 mouse device common for all mice
<USBD - USBD plug>
Register platform device for low battery detection
input: W55FA92 TouchScreen as /class/input/input0
ADC opening  REG_TP_CTL1 = 0xc00
ADC Close
input: W55FA92 Keypad as /class/input/input1
W55FA92 keypad driver has been initialized successfully!
w55fa92-rtc w55fa92-rtc: rtc core: registered w55fa92-rtc as rtc0
Check RTC Level Shift Status
-> Level Shift is enabled!
RTC Access Enable Check
Not Change RTC H/W Power Off Function setting - 0x60085
Init Nuvoton RTC!
<RTC Clock Source is from External Crystal>
i2c_adap_w55fa92_init
w55fa92_i2c_probe()
w55fa92-i2c w55fa92-i2c: bus frequency set to 100 KHz
w55fa92-i2c w55fa92-i2c: Add W55FA92 I2C port adapter
Linux video capture interface: v2.00
Sensor power down
Video capture device 1 initialize successful
jpegcodec_init
jpeg engine is 120000KHz
lm75 0-004e: hwmon0: sensor 'lm75a'
w55fa92-i2c w55fa92-i2c: deal with nack
W55FA92 MMC/SD driver (20140109) has been initialized successfully!
SDHC card will run under 24MHz clock on SD port.
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
After snd_soc_register_dai
w55fa92-dac-i2c ret = 0x0
ADC clock get OK !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
w55fa92evb_asoc_dev = 0xc3f210c0 !!!
SPU DAC ON !!!
asoc: W55FA92_DAC HiFi <-> w55fa92-spu mapping ok
ret = 0x0 !!!, platform device added
******* global g_pw55fa92_adc_data address = 0xc3f25f20
 0 = platform_driver_register
asoc: w55fa92ADC HiFi <-> w55fa92adc_cpu_dai mapping ok
ALSA device list:
  #0: W55FA92_SPU (W55FA92_DAC)
  #1: mach-w55fa92_ADC (W55FA92_ADC)
TCP cubic registered
NET: Registered protocol family 10
IPv6 over IPv4 tunneling driver
NET: Registered protocol family 17
lib80211: common routines for IEEE802.11 drivers
w55fa92-rtc w55fa92-rtc: setting system clock to 2005-01-01 17:32:49 UTC (1104600769)
程序就死在了这里,终端也没有任何反应。
求各位懂的能指点下,
谢谢!
发表于 2017-6-16 09:22:18 | 显示全部楼层
烧出厂提供的测试软件包,先验证硬件是否OK
