[求助]MDK9263老是出现JFFS2 notice: (1103) check_node_data: wrong data CRC in
六年级
发表于 2010-1-11 08:55:05 | 显示全部楼层 | 阅读模式
[求助]MDK9263老是出现JFFS2 notice: (1103) check_node_data: wrong data CRC in data node at 0x027da764: read 0x37f3f138, calculated 0xba7a20cc. 请问何故?谢谢!<br/>开机后出现两个不同的。曾经写入过一个文件,文件系统为jffs2<br/>
发表于 2010-1-11 09:48:27 | 显示全部楼层
<p>jffs2 node的问题,直接忽略</p><p>jffs2和yaffs2相比,如果文件分区大,还是用yaffs2,可以google下jffs2和yaffs2的区别</p>
六年级
发表于 2010-1-11 10:50:44 | 显示全部楼层
yaff2是不是要对内核打补丁阿?貌似内核配置中没有该选项阿 谢谢!!<br/>
幼儿园
发表于 2016-7-22 17:31:53 | 显示全部楼层
Re:[求助]MDK9263老是出现JFFS2 notice: (1103) check_node_data: wrong data CRC
有块板子9X25一开始运行是好的,几天后出现加载文件系统:
UBIFS: background thread &quot;ubifs_bgt0_0&quot; started, PID 657
UBIFS: recovery needed
UBIFS error (pid 1): ubifs_check_node: bad CRC: calculated 0x9f4521f3, read 0x773d4c93
UBIFS error (pid 1): ubifs_check_node: bad node at LEB 388:108784
        magic          0x6101831
        crc            0x773d4c93
        node_type      0 (inode node)
        group_type     2 (last of node group)
        sqnum          44579
        len            160
        key            (346, inode)
        creat_sqnum    1010
        size           2048
        nlink          6
        atime          1461809868.0
        mtime          1475674248.0
        ctime          1467285640.0
        uid            1000
        gid            1000
        mode           16895
        flags          0x1
        xattr_cnt      0
        xattr_size     0
        xattr_names    0
        compr_type     0x1
        data len       0
CPU: 0 PID: 1 Comm: swapper Not tainted 3.10.0 #20
[&lt;c000e3f0&gt;] (unwind_backtrace+0x0/0xe0) from [&lt;c000bfc4&gt;] (show_stack+0x10/0x14)
[&lt;c000bfc4&gt;] (show_stack+0x10/0x14) from [&lt;c013d11c&gt;] (ubifs_check_node+0x27c/0x2b8)
[&lt;c013d11c&gt;] (ubifs_check_node+0x27c/0x2b8) from [&lt;c0143cf0&gt;] (ubifs_scan_a_node+0xb8/0x1c8)
[&lt;c0143cf0&gt;] (ubifs_scan_a_node+0xb8/0x1c8) from [&lt;c01441a4&gt;] (ubifs_scan+0x54/0x2e4)
[&lt;c01441a4&gt;] (ubifs_scan+0x54/0x2e4) from [&lt;c0144f3c&gt;] (ubifs_replay_journal+0x844/0x134c)
[&lt;c0144f3c&gt;] (ubifs_replay_journal+0x844/0x134c) from [&lt;c013a514&gt;] (ubifs_mount+0xb38/0x14c0)
[&lt;c013a514&gt;] (ubifs_mount+0xb38/0x14c0) from [&lt;c0082aa0&gt;] (mount_fs+0x10/0xc0)
[&lt;c0082aa0&gt;] (mount_fs+0x10/0xc0) from [&lt;c0095e18&gt;] (vfs_kern_mount+0x48/0xc4)
[&lt;c0095e18&gt;] (vfs_kern_mount+0x48/0xc4) from [&lt;c0097ca4&gt;] (do_mount+0x6ac/0x7a0)
[&lt;c0097ca4&gt;] (do_mount+0x6ac/0x7a0) from [&lt;c0097e1c&gt;] (SyS_mount+0x84/0xb8)
[&lt;c0097e1c&gt;] (SyS_mount+0x84/0xb8) from [&lt;c0632bfc&gt;] (mount_block_root+0x12c/0x250)
[&lt;c0632bfc&gt;] (mount_block_root+0x12c/0x250) from [&lt;c0632fa4&gt;] (prepare_namespace+0x88/0x1b8)
[&lt;c0632fa4&gt;] (prepare_namespace+0x88/0x1b8) from [&lt;c06328fc&gt;] (kernel_init_freeable+0x170/0x1b4)
[&lt;c06328fc&gt;] (kernel_init_freeable+0x170/0x1b4) from [&lt;c04884a0&gt;] (kernel_init+0x8/0xe4)
[&lt;c04884a0&gt;] (kernel_init+0x8/0xe4) from [&lt;c00093b0&gt;] (ret_from_fork+0x14/0x24)
UBIFS error (pid 1): ubifs_scan: bad node
UBIFS error (pid 1): ubifs_scanned_corruption: corruption at LEB 388:108784
UBIFS error (pid 1): ubifs_scanned_corruption: first 8192 bytes from LEB 388:108784
UBIFS error (pid 1): ubifs_scan: LEB 388 scanning failed
UBIFS: background thread &quot;ubifs_bgt0_0&quot; stops
VFS: Cannot open root device &quot;ubi0:rootfs&quot; or unknown-block(0,0): error -117
Please append a correct &quot;root=&quot; boot option; here are the available partitions:
